141 - 154 of 154 Posts
2003 Safari AWD
Discussion Starter · #141 ·
Electric is all that is left. Not going to stow the winch cable like this. I will remove the hook and store inside.
The welding really tightend up the fit so I just went with it and forced it on scraping the pain off of the shackle mounts. Then used the frame/leverage to pry out the sides a bit and got a better fit.
Re-paint another day.
Tire Automotive parking light Vehicle Wheel Hood
Hood Tire Wheel Automotive tire Tread
2003 Safari AWD
Discussion Starter · #143 ·
Thanks Rod. This really stretched my time commitment, abilities, and patience to see it through.
As of tonight, it is on the road!
To-do list:
  • Get the new light units that go under the headlights
  • Determine where/how to mount the winch controller
  • Power the winch
  • Make new radiator support brace for the hood latch/ bottom grill screw hole
  • Install new horns
  • Install new accessories/lights control panel on the dash
  • Power the lights in the bumper
  • Replace the new driver side front fender with the original after I repair the rust on it. The aftermarket one is shite so I will repair and use the original
  • Re-design the under-hood power panel
  • Make/install/seal roof-rack mounts
  • Paint
  • Rear custom bumper
  • Roof Rack
Vehicle registration plate Vehicle Car Hood Grille
Grille Car Tire Automotive tire Vehicle
Hey I saw this on Matt's Offroad Recovery Youtube channel Yankum rope
The grooves allow you to store the loop and it won't get damaged while drive since it is recessed.
2003 Safari AWD
Discussion Starter · #147 ·
I like it. Thanks!
2003 Safari AWD
Discussion Starter · #148 ·
Back to more electric...
The winch still is not powered, the relays/etc. are still on a plywood board, the fan controller has a sandwich bag protecting it, and the stock fuse box is held in place with a bungy cord.
With none of that complete, I am starting new electrical stuff!
  • Remote control door locks (and maybe turning on outside lights via the remote in the dark/cold winter nights)
  • Remove the current, really good after-market Sony head unit (top right corner) and putting in a double-din Android/Amp unit (bottom-left)
  • TPMS monitoring system
  • OBD/Torque diagnostics
  • Backup camera
  • Front camera
  • Steering wheel controls for phone/music/etc
  • Lighting control panel (lights in the front/rear bumpers, etc)
Ohh... and I took it in to a shop to pressure test the coolant system to find the leak in the water pump that I installed :(
.. and to replace a fitting (that I f&cked up) in the power-steering system that caused it to fail the one-time my wife drove it in a giant storm, at night, and she still got it back home with no assisted brakes nor steering, and simply said "that was pretty difficult"! 🥰
Luggage and bags Automotive exterior Bag Auto part Motor vehicle
2003 Safari AWD
Discussion Starter · #149 ·
After-market Remote Door Locks
I have the unit below installed and working.
There are 4 required connections: power/ground, lock, unlock
Optional connections include:
- rear door/hatch only ( or use it for the driver door only circuit)
- Connections to lights if you want lights to flash when locking/unlocking or finding. probably could do horn also.
Automotive parking light Wheel Tire Vehicle Automotive lighting
The 2 white wires at #1 are lock/unlock configured to apply +12 voltage. (The BCM applies +12 to the door lock relay)
#2 are 3 wires that will go to power
#3 is ground (and an optional trunk only)
Font Electrical wiring Space Pattern Technology
Here it is ready to install. You can see the LED that flashes when locked, the antenna, power/ground, and the 2 white lock/unlock connections. The 2 white wires will connect to the convenience center under the dash near the drivers feet (There is a factory connection there just for this purpose).
Font Audio equipment Cable Guitar accessory Art
Audio equipment Electrical wiring Computer hardware Automotive tire Gadget
2003 Safari AWD
Discussion Starter · #151 ·
!! Important update !!
Way back in post #112, I discussed having the rear shocks "upside down". It was convenient at the time because these new shocks have a much larger diameter so would not fit in the factory mount. At the time, i didn't think it mattered, but it does for this design. These shocks must be installed in the correct orientation for the oil/valves,etc to work properly.
After being able to use the van, I could not get it stop being so bouncy and I just attributed it to too heavy springs and not enough weight (still true but not the root cause). Vast improvement after flipping them over so they can work properly!
-Jim
2003 Safari AWD
Discussion Starter · #152 ·
Everything from post #148 is working. Seems to be a pretty good kit.
This is the Tire pressure system - accurate enough. I installed them and got a warning, sure enough, pressure was low.
You can also see the AuxBeam panel. Only thing connected so far is the lights in the front bumper.
Plant Vehicle Motor vehicle Communication Device Automotive design
Rear camera is nice and clear.
Vehicle Motor vehicle Car Automotive design Automotive navigation system
