Time to replace the sagging fiberglass springs on our '89 Tiger conversion... trying to make sense of the options. It looks like there are two main options:
Use steel leaf springs from a later Astro or S-10 truck, which requires new hangers, u-bolts, and other miscellaneous components, all sourced separately, or,
Buy a fiberglass-to-steel conversion kit that uses the original hangers and appears to include all necessary hardware. Two sources are:
and
The conversion kits sound a lot simpler, but I've seen some comments critical of them, but it wasn't clear quite why? They seem to be rated at 1410# each, anybody know what the original springs were rated at? I'm not looking to add any lift, just to get the rear end back up where it should be, with the extra weight of the camper conversion.
and
1985-1995 Chevy / GMC Astro and Safari - Leaf Spring (Replaces Fiberglass Springs) (Rear - 3/1 Leaves) [AST-1] | $177.72 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
1985-1995 Chevy / GMC Astro and Safari - Leaf Spring (Replaces Fiberglass Springs) (Rear - 3/1 Leaves) [AST-1] | Description SRI No. OEM No. Width PL-1SEA PL-1LEB ArchC No of Leaves Pack ThckD Spring Capty. Remarks AST-1 None 3 25 29 1/2 4 1/4 3/1 1 7/16 1,410 Two stage; 1985-1995 only; Replaces...
www.sdtrucksprings.com
