Hi Everyone,
I've been wanting to build an LS powered AWD Astro for a while now. I started searching for parts and came across a couple things. The first is this pretty awesome Holley "Mid-Mount Complete Accessory System" or MMCAS for short. It's not cheap at $1800 for the base setup but it's pretty awesome how small it makes everything. The AC compressor and alternator pretty much sit directly in front of the heads. Check it out...
http://www.superchevy.com/how-to/engine ... ap-answer/
http://www.hotrod.com/articles/holleys- ... ger-swaps/
https://www.holley.com/products/accesso ... lete_kits/
https://www.summitracing.com/search/bra ... ry-systems
Because I want an AWD AStro/Safari, I'm also looking for cheap, shallow, steel oilpans that may fit or can be easily modded. I came across these...
Jegs 555-50228 - 6QT steel, remote oil filter required
$200 - $160 for the pan, $40 for the pickup
https://www.jegs.com/i/JEGS/555/50228/10002/-1
Summit SUM-G3610B - 7QT steel, remote oil filter required
https://www.summitracing.com/parts/sum-g3610b/overview/
Here's the non-cheap ones that I was also checking out:
Holley 302-2 - Aluminum pan with integrated filter mount
$379 complete
https://www.summitracing.com/parts/hly-302-2
Canton 16-278 "S-10 Conversion Pan" - 7QT steel
$555 - $274 for the pan, $111 for the pickup, $170 for the oil filter adapter
https://www.summitracing.com/parts/ctr-16-278\
https://www.cantonracingproducts.com/cg ... key=16-278
If everyone already knew about this stuff...nevermind.
Later,
Ben
$379 complete
Later,
Ben
