1 - 6 of 6 Posts
I have had a p0102 code for a while now, and have checked for leaks around air box / throttle body, removed K&N filter and replaced with paper one, replaced MAF sensor with refurb unit from Murrays, replaced hose from side of throttle body to crankcase, replaced PCV valve with new, and I am still getting this code.
I checked the ground and voltage at the MAF and had ~12volts, and ground was about 30 ohms above battery ground.
Any ideas on what to try next???
I am at 178K if that helps.
2000 GMC Safari RWD
Thanks for the help!
30 ohms resistance in a ground circuit is too much. The maximum allowable on any ground is .75 ohms.
Discussion Starter · #4 ·
I am having the occasional hesitation and misfire. I have cleared the code numerous times, and it keeps coming back.
Anyone know which ground point that the MAF grounds at?
I guess I could temporarily run a separate ground for the MAF.
Thanks for the input....Keep it coming! :D
Discussion Starter · #5 ·
Thanks for the info, I checked the signal wire.....and no voltage. I found the wire was broken where it comes out of the loom just before the sensor.
Repaired wire and MIL is gone.
Not sure that all problems are gone, but I am keeping an eye on it.
Could driving it with that problem for a couple of months have caused any other issues (too rich, too lean, etc)
Thanks again. :clap:
You should be OK.
Driving it for a while should barf out any carbon buildup that has developed.
1 - 6 of 6 Posts
