I ordered Magnaflow Direct-Fit, High flow CAT with Pipes. I bought from AutoAnything.com, priced at $285.42. I found a discount code online and got 15 bucks off. So including shipping from Californina to South Carolina, I paid $270.42. Not bad, I think. The nice thing about ordering parts is the time you have to prep and plan. While waiting for the CAT to arrive, I was spraying the exhaust bolts daily with PB Blaster. The other day, I broke the nuts loose and purchased my gaskets at Advance Auto Parts. I was worried that the nuts would be BEARS to remove, but it's really an easier project than changing plugs. I did have a friend helping me, but the entire project took a little over an hour. (would have been quicker if another trip to Advance was not required - I'll get into that later) I had no problem getting access to the nuts with a large assortment of 3/8" wobble extensions.
Once all the bolts were off, I braced the transmission with a jackstand. I dropped the steel cross member, pipe hanger bracket (Probably unnecessary) and disconnected the 3 o2 sensor harnesses. At this point, it popped right out with no problem. We compared the old cat to the new and saw that the Magnaflow had 4 holes for o2 sensors and my van has only 3. I was not expecting this, but figured for now, we could buy an OLD Ford sparkplug to fill the gap. Thus, the trip to the parts store. (any suggestions for a nicer fix?)
We set the new gaskets and the new CAT fit perfectly. We bolted everything up and plugged it all back in.
When finished, I cranked it up and checked for leaks- All good! I found this to be a VERY EASY install. Probably easier because of a weeks worth of spraying with PB Blaster on the nuts. I have been driving my Astro with a hollow converter for a few months. The new High-flow converter eliminated the "airy" sound that I was getting. I am surprised though that the sound is actually a bit "throaty" with the stock exhaust. Especially in revs and acceleration- cool! I can definitely feel a huge improvement. (Duh! - Hollow converter) Can't wait to start on my CAT back.
