221 - 234 of 234 Posts
That is too bad. Mercedes made another I5 turbo diesel that put out only 30 hp less than the 4.3 6 but about the same torque. He might want to try that one. Nissan makes a diesel TD42ti that is 4.2 liters and an I6. I am guessing that because it is about the same size as the 4BT but is 6 cylinders instead of 4, it will be quite a bit shorter than it, so radical lists should not be necessary. Performance specs are similar to the V6 I have been following diesel conversions for quite a while now. The size of the engine is one of the drawbacks, but the weight is also an issue. Our 'stros are only half ton, and it is weight that directly sits on top of the front axle, something that is already a little overweight. Is there any way to beef up the front end for an extra 200-300 pounds?
Discussion Starter · #222 · (Edited)
Pengyou said:
Did this project ever come to a successful completion?
Life got in the way, got married, had a child, ect. Unfortunately lost all the images in the photobucket upcharge thing as well.
Van is now a parts van in my shed.
Discussion Starter · #224 · (Edited)
Update-
12 years later I still have this van and have decided to make it run again (eventually). I was prompted by the discovery of all my old pictures of this project on an older external hard drive, so also intend to try and get a lot of the pictures back up on this thread. All were lost in the photobucket thing back in 17.
The van has spent the last 8 years living in a shed, and the only part I stole off it was the drivers seat, so if I can remember anything of where I was on this project, then I should be able to pick up up where I stopped once I clean 8 years of mouse crap out of it.
Here is its current state-
· Moderator
Update-
Discussion Starter · #227 ·
I remember this build, but it was a red one , correct?
Mine was 14 years in the ched, started a few weeks ago with the build
I think you might be thinking of coyoteX build maybe. Ironically both our vans were burgundy, but i painted the outside of mine green
His was complete with a 6.5 diesel installed out of a G series van
Your time frame gives me hope!
Discussion Starter · #228 ·
Im working on readding original pictures but ive just run across a little known forum restriction- at least for the old posts I may not edit more than 10 different posts over 7 days apparently. Eventually Ill get them back up.
2003 GMC Safari AWD
I've been thinking about the OM605. I think the OM606 is too long to fit without moving Tranny? Both of these engines can be mechanically run and produce very nice HP. See youtube - dieselpumpuk.
How did the OM617 fit?
Discussion Starter · #230 · (Edited)
The biggest dimensional change i had to make was height, mostly for removing the valve cover inside the engine compartment, i needed huge clearance above for that deep cover.
What i ended up doing was a 4 inch subframe lift, then installing drop spindles to drop the lift down to 2 inches.
Im not familiar with the 605 and 606, i dont think they have the same super deep valve cover do they?
Lengthwise the 617 fit perfectly, just had to make changes for the taller engine.
EDIT- i should clarify that the 616 and probably the 617 fit in the engine compartment height wize without any modification, apart from the impossibility of removing valve covers.
2003 GMC Safari AWD
Do you have a Body lift on yours? I have a 3" front body lift on mine, so I'm thinking I may do the OM617. Cheaper and easier to come by. Finally how is the driving with the 617? Is it sluggish?
Discussion Starter · #232 ·
I never put many miles on the van with the 617, i had a vibration issue from improper balancing and it was geared wrong for the half powered 616. I needed to put the original diff back in.
I have a 4 inch body lift and 2 inch drop spindles.
Discussion Starter · #234 ·
I hope to see the pictures again. I really enjoyed watching the build and hope you get her back up. 👍🏼
Thanks!
Im in the middle of constructing myself a dinky little shop space and the first thing im intending to do is finally get this van running.
