FINALLY some updates-
Have my new 2 year inspection sticker! within 24 hours, van was off the road being ripped to pieces! :mrgreen:
After getting the final inspection, I was finally able to put this van in the air, and I thought it was in good shape for rust, the subframe was rusted out for the front mount locations.
4 mount locations are holding but all are rusty unfortunately. Good news that im using the other modified subframe. Ill hold onto this though, as it is pretty decent shape compared to the first one.
after the engine was out, rigged up a jig to control stock ride height and angle for the replacement drivetrain. This is specifically so I don't mess up how high the stick ends up being coming up out of the floor.
i also have some rust on the body to deal with, only part that needs fixing though, apart from some rust in the rocker that can be resolved after the subframe is put back up-
Using that jig, I set up the new modified subframe, and got the correct engine height for the diesel
Good news on the throttle, I should be able to use the stock cable throttle on the diesel without incident. Interesting, it circles around the entire engine bay, and comes around to the driver side of the engine from the passenger side. thing is about 8 feet long and will be useful for adapting to the diesel throttle linkage-
big issues to work out not resolved yet, steering and oil filter. Of the two, steering will be the number one problem here. Im toying with dropping the whole steering assembly and making the pitman arm longer off the steering boxlots of room for a remote oil filter here though, where the stock fuel filter was-
starter fits perfectly though. I was worried about the location in relation to the lower control arm on the passenger side
More updates as progress takes place now that I can actually work on this.
