This morning i when out to move the van to install the transgo servo's that I ordered and it started and ran a little rough ran for a total of about 30 sec then just shut off like i turned the key of ( no stumble or anything ) just shut off and now it will not start doesn't even sound like it is firing. I've replaced the fuel pump last week because of low fuel pressure. The The ECM is from a Junk yard. The orig ECM was a #4482 so I replaced it with a #7747 ECM. I have noticed that the last couple of starts it would run rough until it warmed up then ran fine. Another intermittent problem is an idle issue, sometimes when in gear it will idle down to an almost stall then recover. It will do that when in neutral as well but not as extreme as when in gear. I'm thinking Its an ecm issue. The ECM looked old like it had been on the shelf for awhile had some rust stains on cover. I got it anyway because i needed it for a core and decided to try it out first before buying a reman ecm. The ecm prom is new from http://www.tbichips.com .I haven't checked to see if there is spark but will do that now. Will post results of the spark check. If anyone has any other ideas please chim in. :banghead:
