Thanks Will.
Well, the final chapter here (for me) was to do the VCM/PCM wiring mod.
While not essential to the transfer-case upgrade... without this mod you are limited to 1st & 2nd gear manual shifting only. This wiring mod regains FULL automatic shifting while in 4-LO.. and regains all 4 gears.
96-2000 VCM's are different than 2001-2005 PCM's.
I used the top mod shown here (for my 2000) -- using connector C4 (black), terminal 23...
I disconnected the battery before disconnecting the VCM connector.
The connector was easy to reach and unplug, without removing anything.
The cable was long enough to pull up to a working area above...
The plug must be opened up (parts un-snap and pull apart) ...
I've read that you can use a female pin from a computer connector (DB9-DB25)
(this was my biggest uncertainty.. whether I needed a male or female pin)
(I used an accy pin/wire from a Motorola radio I had available)
Here is the wiring view from behind (we want to add pin #23)
Here is my pin (pushed in though the back and snapped into place)...
And finally, I snapped the connector back together, spliced and ran the wire to an under-dash toggle switch, which switches this mod to ground.
It works perfect! The job was less difficult than it appeared reading about it.
Test drive: I now have auto shifting of all 4 gears while in 4LO.
Note: the switch should not be engaged while in standard high-range.
Naturally, I tried it to see what would happen, and the trans seemed to go into neutral or something.
I didn't want to chance it further to see what might happen.
Later on I may consider some kind of automatic switching attached to the lever or linkage.
DONE!!!
I beefed up the cable mount though the floor..
...as well as the attachment to the shifter arm...
Here's a photo of the entire cable shifter (I didn't post earlier) from floor to TC bracket...
(click to zoom)
I'm officially DONE!
Well almost... 4x4 emblems/badges are on order! :mrgreen:
