FINAL TWEAKS:
I don't think anyone has ever mentioned this... but it's possible the 233 case (being notably smaller) may put the output shaft a little lower and at a little more of an angle to the driveshaft. The rear trans-mount mounting pad might sit at a different height position. While I haven't had any vibrations, the angle variation at the u-joint is quite noticeable. I tried to take measurements, but couldn't get anything accurate. It did measure roughly 4-5 degree angle difference between yoke and driveshaft... visible to the eye.
So I shimmed up the rear trans mount using some thick washers/spacers.
I estimate overall about 3/4" (or more) of spacers total.
The old angle (not the best photo)...
The corrected angle after spacers (looks much better)...
My spacers (under trans mount)...
Besides under the mount... a couple more (not in picture) were added between the mount and case.
The angle appears much better, and is smooth on the highway.
I also gained an additional inch or two higher clearance, especially at the driveshaft.
FINAL CHAPTER:
Well... the job isn't really
completed until the finishing touches.. until the badges are applied!
I can't decide which one I like better.. or if I'll just keep both!
#1
#2
The badges were just a few bucks on ebay (from china)
Two "different" badges (on the rear) may be overdoing it.. I want it to look "factory".
I also intend to add #1 to the side doors (remove AWD and replace it with 4x4)
I have chome 4x4 badges too.. but the red seemed to more closely follow the factory AWD scheme.
