In the next few posts, I may repeat some details, in hopes of not missing anything important.
My NP233C came out of a 2003 Blazer. The "C" stands for Chevrolet.
I purchased it for $175 on Ebay (included shipping)
It's my understanding that even though models may be interchangeable, there may still be slight indexing issues with the older models. The incorrect index could result in interference between the front drive-shaft and the cross-frame support, but can be cut to fit. I will post later if mine lines up correctly.
For Gen 2, you will need the 32 spline.
It is supposed to completely bolt up, using same driveshafts.
Below is the list from JourneysOffroad.com (a valuable source of info)
Click here for more details: http://journeysoffroad.com/swaping-in-a ... rcase.html
This is the manual conversion kit offered by JourneysOffroad.com
I opted to make my own
The tag on my unit
Well, well... it's finally my turn to do this upgrade!
I keep finding myself working on job-sites pulling heavy loads off-road desperately needing 4-LO range gearing and full time 4x4 operation. The 4.3 in the single high range AWD with taller tires and stock gears just isn't working well for me at all... it generates a lot of sudden heat... it struggles badly and is severely under-powered... and it REALLY puts a strain on the trans too. The AWD system has reliability and operational issues too, issues with sticking or failing encoder motors (99-up), issues with clutch-packs and wear, but most importantly lacks a very needed low-range gear.
I considered both the NP233 vs the 236 transfer cases... but since I do not live in snow country, I do not need the benefit of the auto AWD, or the complexities of the 236 installation. The simple drop-in NP233C was chosen!
I have also chosen to go with the "manual" shift conversion vs the electronic push-button shift, for both simplicity, dependability, and reliability.
I'm re-posting a couple of posts (from a couple different threads) so I have it all here in my build thread. This was the start topic...
NP233 vs NP236: https://www.astrosafari.com/viewtopic.p ... 9&t=135734
July 5, 2018:
UPDATE: My "new" 233 unit arrived today! :mrgreen:
Actual unit weighs only 68lbs... much lighter than I expected.
I purchased the unit though Ebay, $175 (including shipping)
This unit is from an 03 Blazer. I confirmed it has 32-spline output.
I've read there may be some case indexing issues old vs new.. I'l let you know how this one does.
The unit is light enough it can be lifted and carried with one hand.
I turned everything by hand and verified the 4x4 Hi/Lo selector is working.
The new basic gasket/seal kit arrived today as well... $12 on Amazon.
Now to fabricate my manual shifter.
I'm learning toward possibly something similar to this that "LiftedAWDAstro" did on the other site... but perhaps either a little shorter, or further back.
I will experiment with leverage lengths and angles once the cable is in place.
I have a box that sits in the center between the seats, so this really won't be visible.
Looks like I may go with this Lokar S-7100 cable kit ($50 from Summit) connected to a simple shifter mounted to the side of the driver seat facing forward. I think I'd prefer the shifter close as possible to the seat vs cutting open the floor.
This cable kit appears to have everything I'll need (except actual shifter lever)
But I'll probably take a visit to the junk yard just to see my other options.
I'm pretty excited about taking this to the next level!
See more at NP233 vs NP236: https://www.astrosafari.com/viewtopic.p ... 9&t=135734
July 7, 2018:
The new unit is here.. I'm just shopping for my best linkage solution. Still undecided on the Jeep Liberty shifter (found a nice one in JY yesterday).. or making my own (shifter mounted on the side of the seat base). The Liberty shifter will be the simpler and cheaper choice, and comes complete with everything I'll need. I'm probably going to go back and pull it Monday, regardless. The cable though the floor to a simple seat mounted shifter is my preferred choice. But once I cut the big opening in the floor, the choice will be made.
Mmusicman, thanks for the great write-up! I am getting ready to swap the transfer case in my 2001 Astro AWD for the NP233-C and need some help finding the right T-case.Well, well... it's finally my turn to do this upgrade!
July 5, 2018:
July 7, 2018:
