1 - 16 of 16 Posts
I was wonder the brand of spoiler.
From what vehicle it originally came from.
Can you get another picture of the spoiler?
Did you raise your van 2+1 or more inches?
The widows are changed. Is a Camper van now?
2000 Astro Archer conversion. 4x4 kit. 73k miles as of 3/13/22
Discussion Starter · #7 ·
Im sure the spoiler is made for astros. I will get more pictures soon. It has 3" body lift, torsion keys, hd s-10, and jor lift hangers. The step makes it look lower. The windows are from the conversion. It also has the 4x4 kit and full moog ps front end.
92 stro base
After seeing yours, I did look about and saw that there are spoiler kits along with other body kits available.
I don't know why I didn't already know that. A few months ago, there was a guy from Poland on here looking for information, and his was done up to resemble "The A Team" van, which had a spoiler. I guess I was so caught up in the mimic that the spoiler itself was overlooked, whereas in the case here, we have a standard camper van paint job, so aside from the lift, the spoiler stood out more even though it was not so obvious.
I started devising a plot to determine if I can incorporate one in such a way as to seal out the topside weatherstrip leaks on a barn door.
Discussion Starter · #11 ·
92 stro base
Ah, yes, generic weatherstrip. I thought you had found OEM style.
Have you tried with generic and it work? I feel that if the OEM didn't fit well, a generic won't either. I have tried a generic type on the body side mating surface opposite of the OEM rubber. It has slowed it considerably, but not eliminated completely.
Discussion Starter · #13 ·
Mine has worked for a year so far. I cut the old off at that big foamy piece where the upper and lower doors meet. Just pull out the steel in the weather strip and cut around the henges. Glue the ends to the foamy piece. It works just take your time with the cuts.
1 - 16 of 16 Posts
