Since the remodel is spreading to the entire house, I will be redoing the living walls to:
-remove the knob and tube wiring
-adding more outlets
-correctly routing the cable and surround sound
-reframing the windows
-adding insulation
-etc, etc, etc
it occurred to me that I could mount the flat screen on the wall instead of using the cumbersome entertainment center we have. While looking at the back of the flat screen, I noticed that there is a VGA plug and then read in the owner's manual that it can be plugged into computer. Cool! But of course the problems is that the computer is 20 feet away from where the flat screen will end up. And of course, I would then also want to run an audio feed the same distance.
So I been looking at adding a couple VGA face plates from the computer desk to the flat screen. Anyone have some ideas and/or tips on how this could be best handled? And yes, I assume that the audio feed would run next to the VGA cable. I've read about wireless setups and also data converters that use ethernet cables. I'm not sure about how much money would be too much but I liked to hear as many different ideas as you have.
Thanks,
Jim
-adding insulation
-etc, etc, etc
Thanks,
Jim
