21 - 32 of 32 Posts
Discussion Starter · #23 ·
I keep looking at this picture and am puzzled. I been reading into the differences between component, s-video and hdmi lines. I read that hdmi also carries audio with the video signal. Is that true? If so, why would the face plate pictured above have component connectors?
· Premium Member
Those are component RGB (Red Green Blue) video-only connectors and do not carry audio. The top connection being Toslink optical audio that does not carry video.
So you've got the right idea. You could use either:
1. HDMI for audio and video
or
2. RGB for video and Toslink for audio.
You wouldn't ever use all the connections, but it would be nice to have the option. I guess I just was giving one example of a cool wallplate, not specifically recommending that particular one.
that type of plate would be so you could use one plate for multiple applications. like the rgb and optical for a theater projector and then the hdmi in a separate room such as in the kitchen to look up recipes on the computer
Discussion Starter · #26 ·
You could put all of your equipment accross the room and then get one long ext wire for your mouse and one long ext wire for your keyboard , thats all you really need is your mouse and keyboard .
Another option , this ones more expensive but they have wireless mouse and wireless mini keyboard for $80 bucks and it has a range of 50 foot and works around corners.
I like extension wires myself because if mmy keyboard ever goes bad i can pick another up cheap.
Discussion Starter · #29 ·
astro355 said:
I wish I could move the computer closer to the TV, that one is out of my hands *cough*wife*cough*. I already have a wireless keyboard and mouse. I'll have to run wire to make this happen unless I do the wireless setup. Which really isn't a bad idea.
I would then have to run a VGA wire, a printer cable, speaker cables, and usb from that area to the computer desk. Seems easier and cheaper to run a hdmi cable instead. But as already stated, the wife wants the computer to be in the computer desk.
Discussion Starter · #30 ·
This is a trial run of the hdmi setup. Sees to work great. The only "problem" I've noticed is that I can't run the sound card and hdmi output on the same application at the same time. On Win XP, I can only have one or the other set as the default at the same time. Not a terrible thing, just kind of annoying to have to switch back and forth.
21 - 32 of 32 Posts
