Need Help: Replacing water pump, fan?
1478 Views 5 Replies 4 Participants Last post by  jaydee
98 Safari. I'm in the middle of replacing the water pump and can't figure out how to get the cooling fan out of the way.
Do I remove the pump and fan as an assembly? If not, how do I remove the fan?
Thanks loads.
JD
1 - 6 of 6 Posts
1 7/16" wrench on the large nut right behind the fan. It's right hand thread.
Ok, just so I have it clear: I put a big wrench on the big nut and turn it CCW, ie. to the left?
Thanks, now all I've got to do is find a big skinny wrench.
JD
Thanks for the help guys. I just finished installing my water pump. It was surprisingly easy, the only hard part was getting the fan off.
Thanks again.
JD
1 - 6 of 6 Posts
