Greetings,
I have a 1992 Safari 2WD. I replaced the fuel pump about a year ago. However, it's not starting again. It is getting spark, fuses are good. When I spray starter fluid into the carb it seems like it's going to start, then just turns.
Two things: I do not hear a click in the fuel pump relay, not even the new one I bought (even did the 9V battery test). I was wondering if that's typical of this model's relays?
2. I bought a 6-12 volt power tester to see if the relay harness was getting power (under the hood). It never lit up. Could this be a bad harness? Are there any other harness tests I could do before I dig into the fuel pump again?
Thanks so much for the help!!!
