Well... I FINALLY found my problem!!!
If you've been following me for the past 1/2 year or better... then you know I have been fighting a very serious "over-steering" issue with my 92. On the highway, if I didn't hold the wheel perfectly straight, I would easily get a pretty bad "wobble" going down the road. But the bigger problem was on gentle left turns where it would suddenly and pretty violently over-steer on me, as if the front end was suddenly shifting strong left from under me. Right turns were fine. It felt like the front end had a mind of it's own! This over-steer issue was bad on slow left turns too, like at intersections, where you could still feel it over-steer to the left.
Over time, I have inadvertently replaced almost all of my entire front suspension... with some of them hoping to cure my problem.
Here's a list of all the parts I've replaced:
* New front Moog progressive coil springs
* New upper and lower ball-joints
* New upper control arm (including upper ball joint)
* New upper control arm bushings (included with control arm)
* New lower control arm bushings
* New sway-bar bushings and links
* New idler arms
* New tie-rod ends
* New steering arm drag link
NONE of these parts solved my trouble... but did cure the "highway wobble".
I discovered my body bushings were shot, and the front right size was broke.
I was almost sure this MUST finally be it!
Temporarily "fixing" this did not change anything.
I spent a lot of time doing alignment adjustments as well, trying different things, with no effect.
With my final alignment, I was able to get perfect tracking on the highway.
But none of this solved my serious left-turning over-steer issue.
In addition to almost every part listed (that could be suspect)... along with suggestions of possible alignment issues... it was also suggested my issues could be tires, could be the "rake" (angle my van sits at)... could be the extra interior weight or unbalanced load, or could be maybe just the need for a good rear sway-bar. Of course, most of that wouldn't explain the problem with left turns only.
I started in a fairly logical order (based on fairly logical assumptions). The upper control arm bushing on the PS looked like it "might" be messed up, with some visually separated rubber. When that didn't solve the issue, I figured maybe it could be the lower control arm bushings too, which had never been touched. The ball-joints were sloppy.. sway-bar bushings were falling apart, and the tie-rods and drag link as well as most everything else were all 25 year old factory original parts with almost 300K on them, so it seemed like a good idea to replace them regardless. The springs were replaced (unrelated)... to accommodate the V8. I even had the PS upper control-arm support re-welded to frame in one spot where it looked like it might have been cracked.
Here are some photos of the final and most recent steering parts, the tie-rod ends and steering drag-link.
(most of the other suspension stuff I've already posted)
New tie-rod ends...
New steering drag link...
I finally concluded I had NOTHING ELSE LEFT to replace except the steering gear-box itself! I had previously made "adjustments" to it which didn't seem to help or change anything, which may be in part why I didn't originally consider the gearbox to be the culprit. I also replaced all the other things in order of logic, importance, and least amount of work and cost... so the gearbox was going to be last anyway.
So, I FINALLY changed the gearbox!
I was down to deciding between an ACDelco reman box for about $120 (from Rock Auto) plus shipping, plus shipping the core back... or buying a Cardone reman unit locally from Advance Auto for $100 (after 30% discount) dealing locally with no shipping charges, and no core shipping charges either. If I had a problem with the unit, it wouldn't be a problem to exchange. So I opted for the Cardone unit from my local Advance Auto parts store.
It came in a generic box, with NO Cardone brand markings anywhere on the box or unit.
(I've read that many off-brands are possibly re-manufactured at the same plant in Mexico)
The old unit wasn't hard to remove... had it out in less than 1/2 hour. I did not have any issue separating the drag-ling from the pitman arm (was only about a week old).. the steering shaft removed easily, the pressure lines removed easily, and the main bolts came out easily without removing the tire. Things that made the job easier to get to was loosening the DS idler arm, and eventually removing the battery (should have done that from the start).
I put the old gearbox in the vice to remove the pitman arm (came off easily too with correct tool.. no heat necessary)
My "work-shop" rain or shine: (my garage)
My little helper: (he thinks I put that pad down for him!)
Here are photos of the old gear box gears (showing a lot of wear)...
Note the arrow points to a seriously worn gear spot (positioned in the left turn)
(click photo to really zoom in)
Looking up... It's in! (very easy access)
Looking down... New return line after cross-threading the old one:
New M16x1.5 fitting came with 2' hose (I cut pipe short to fit nicely, see above photo)...
I flushed the system using some very old fluid I had kicking around that I would never use otherwise.
I have never heard of this brand and NO idea how vintage it is! LOL
The idea was to flush the existing "clear" PS fluid, when I see red I know it's fully flushed...
then keep adding new PS fluid until clear again.
It's been several decades since I punctured a can and poured one!!!
Catching the fluid was easy enough (but a little messy when I first separated the line),
using the return line to discharge the old fluid, turning the wheels back and forth,
and cranking the engine a few times too, all while adding new fluid.
Here's my catch setup the first draining and flush...
(the 2nd time I used a large clear jug)
The highway "test drive" was AMAZING!!!
It feels like a NEW van!!
No wobble, no slop, no drifting...
It feels like all new front steering components should... tight and accurate!
I go down the road straight as an arrow and best of all...
The "over-steer" issue is GONE!!!
Here's a video showing the old gearbox.
Note the clunking noise when I turn the steering wheel left, but no clunk straight.
Then you can "see" the play while in the vise:
(I have another minor issue to deal with now and explain, which I will do in the next post)
* New idler arms
* New tie-rod ends
New tie-rod ends...
