I haven't posted here for some time, as my Astro has been running GREAT!
But lately it has had a HARD START issue. Initially fuel pressure was good, so I replaced ignition cap & rotor and took the van for a 1200 mile ride, towing a camper. Everything was going great - until it died...
Around the time it died, starting may have been a little harder than normal and it did stumble and die once on me.
Checks on the roadside showed ZERO fuel pressure at the rail. No sound of pump initializing at all. CHECK GUAGES light on dash. Manual cited this as possible pressure switch issue.
Assuming pump failure - Fuel pump replaced and after that did nothing - Oil pressure sender replaced.
Turning the key on gives no initial pump prime. Extended cranking - same still no pressure at rail.
Current codes - 147 (02 bank 1 sensor 3) 401 (egr recirc flow insuff) 452 (EVAP press low)
From past experience with missfires, I checked connections to fuel pump and 02 sensor with tank on ground - and it fired up! When tank put back in place - NOTHING. Back to square one.
My thought was a bad wire coming back to pump - because of INTERMITTANT fault - but watched AstroWills video on the relay circuit and I'm wondering how far off I am.
Tools on hand - fuel pressure gage, OBD II scanner, FLUKE multimeter, M/L service manual. Any advice where to start searching for voltage appreciated. Glad my van made it all the way from Ontario Canada to Florida before dying....
