41 - 49 of 49 Posts
ok got all brand new rubber vacuum lines, getting vacuum from engine just fine now, got a new hvac control check valve, all vacuum lines are hooked up properly, yet I still cannot get any of my baffles to operate, any suggestions?
2002 astro.
my mechanic says I need to find this part my permanent defrost issue.
1: I am stumped to find this part on the interenet
2: I thought it was just going to be a vacuum line.
(defrost always on, I checked the lines and swapped out the temperature actuator)
any info of what this is, if it may be the issue and where I might find a replacement.
I'll keep searching other forums, in the meantime
Gas Water Flooring Building material Wood
Super Moderator
05 Astro AWD
The vacuum actuator from under the passenger side knee bolster?
I replaced this a few months ago, nothing changed.
I still think its the vacuum lines, but I still only have defrost.
Automotive tire Automotive lighting Automotive wheel system Auto part Rectangle
My buddy said the picture of the part he has in his hand, came from under the passenger dash cover
Super Moderator
05 Astro AWD
Yeah, that’s what I said. It’s a vacuum actuator from under the passenger knee bolster.
EDIT: GM calls it the mode actuator
Automotive design Motor vehicle Font Parallel Automotive exterior
I am working on the same problem. In my taking this actuator off the little spring that goes on the lever came off and I can not figure out what way it goes.
I hope you've figured it out by now.
this part is impossible to find, ordered a jeep part that looks similar.
months later (I am overly busy) and still have this thing torn apart.
I think defrost only, might be in my future.
41 - 49 of 49 Posts
