1 - 7 of 7 Posts
Well I'm back at trying to get this thing started again. 1995 Astro W engine, back to no start again, no spark or intermittent spark. Distributer,pick up, coil and wires are all new as are fuel spyder, regulator, computer... O yeah and exhaust. Only thing I haven't replaced is the wiring harness. What should I check first?
Thanks
Ross
· Super Moderator
Have you checked the engine ground yet? I'm guessing with all the new parts that there's a new distributor cap, rotor & plugs in there too. In the past I've had new plugs foul out on me VERY quickly in the driveway with 0 miles on them. It doesn't take much to do that anymore, just a thin film of unburned fuel or oil will do it.
Also, have you checked the plug @ the distributor & the wiring harness between it and the ECU? Pinched/broken wires can make you chase your tail for hours.
Any codes in the ECU?
Gotta run, time to replace my fuel pump!
Discussion Starter · #3 ·
I think I checked the engine ground. One at the battery, one on the left rear of the block, another on the frame. I get sporatic codes, the last was TPI low voltage. Would not change with throttle position. My gut is there must be a short somewhere, but I don't know how to find it. I pulled the connections off the computer, pulled the entire wiring harness into the engine compartment and ran an ohm meter from the end of every wire to the computer... found none with high resistance. Last time it ran, the shop replaced the computer claiming it was the problem....it ran for about a week....a/c compressor clutch died....after getting the compressor off tried to start it to move to a different place in the yard. no start and it has been there since early March.
Discussion Starter · #5 ·
Gary, thanks for the vote of confidence on not being a quitter. Could mean I ain't to brite either. Actually haven't done anything on it for months. Work keeps me busy. I agree with the electrical shop. Just haven't found one in the local area that doesn't want more than the van is worth just to look at it.
Ross
· Super Moderator
I had an 87 S10 that had electrical problems for 2 years. I bought it new. I would have to unplug the alternator to drive it in the morning before it warmed up. Once it warmed up I could plug it back in and it would run, but not well. I replaced sensors, hooked up the $3K Snap on scanner, nothing. Replaced 3 alternators, ECU & PROM together(that helped for a month). Finally to appease the Mrs & the in-laws, I let it go to an electric shop. They had it for 3 days, gave them $75 when it was dropped off, then they told me there was an echo in the fuel circuit, and they "almost had it, we're close" but it would be another $225 for diagnosis only. I picked it up, they hacked up my harness, they put a butt connector less than an inch from the ECU connector, they left a razor blade on top of the radiator, and were no closer to fixing it than I was.
I eventually found it- it was the sensor(cam/crank sensor?) under the rotor button, above the ignition module. EVERY FLAPS in town wanted to sell me an ignition module when I tried to explain it to them. I eventually got a good one from the junk yard. I kinda wish I hadn't, because had that sensor not worked, I had a 301 turbo on the stand waiting for a home. That sensor was the last straw.
Bottom line- If it's going to a shop, find one that's got a SOLID reputation of being able to fix ANYTHING, not just someone with "Electric" in the name. If you don't have time to deal with it, that may be the best course to take.
Discussion Starter · #7 ·
sounds like good advise. I have a couple of friends who are ex GM mechanics who may have an idea.
Thanks
Ross
1 - 7 of 7 Posts
