Can you measure the output of the injector wires with a multimeter instead of using a noid light ?
i was thinking it would be just 12 volts applied to the injectors for a certain amount of (ON) time so i was thinking i could use a digital meter or mayby a analog meter would work and it would just flash 12 volts
Do you think it would work or do NOID lights have somthing special about them ?
