Some new seals while I wait for the journeys shift kit to come
got it from Amazon, was here in two days. Here’s the link.I like that rear seal. Where did you get it. Congratulations on the build.
Thanks for the tip, you just put spacers in with the bolts for the trans mount I think right? Ran out of sunlight so I’m gonna finish up in the morning. Install has gone well so far, needed up not needing to take the front driveshaft out, but sensing I might want it out to get the crash support brace bolt off the engine block, we’ll see.Didn't reuse skid plate with mine.
You might want to consider how much smaller the 233 case is compared to the AWD case. I wound up spacing mine up quite a bit to get back correct drive-shaft angle.
