Hey all, I'm here to ask the experts and could really use some insight. I'm wondering if anyone knows if aftermarket Impala upper and lower control arms bolt directly to an Astro frame and spindle?
I'm building a hot rod truck and have read that Astros have the same geometry as 70-81 Camaros, 73-77 A body Chevelles, '78-96 B body Impalas, and some Caddys. I want my truck to handle well enough to have occasional fun autocross racing it, and I have access to a good 2003 Astro 2WD subframe that I'd like to use. I know for sure Camaro performance geometry correcting tubular control arms are a direct bolt on (same design) as the Caprice/ Impalas, and there are a couple companies out there that make these arms specifically for Impala SS' and 9C1 cars with the 5/8" ball joints.
Lots of guys have used Astro lower control arms and 9C1 Caprice spindles to convert Caprices to the larger lower ball joint but no one speaks of swapping Astro upper arms onto a Caprice/ Impala. So the big remaining question is do Caprice/ Impala upper arms swap directly with Astro 2WD upper arms?
Thanks for any insight! -Ben
