Hi i have a 1991 Astro with power window and power locks. My passenger side has been without power for a while. The power windows and locks didn't work. The other day i decided to see what was wrong, so i took the kick panel off, and found that every single wire except for 1 was cut. So i went to work and striped all the 13 wires and spliced them together with butt splice connectors. After all that work, the window still didn't work, but the power locks did though. Now i don't know if i need a new motor for the window. Does anyone know how to check for power with a multimeter? And is it hard to replace to motor? i know its very cramped, but does it go in easily?
Oh and i thought i should mention, when i was stripping the wires two of them accidentally touched (i don't remember which ones) and sparked a little. Do you think that could have damaged something? I was too lazy to take off that negative terminal but after that i did.
Can anyone help me out. I really need my window to go down for the summer because the A/C doesn't work and it gets hot as hell in there.
Thanks in advance.
Thanks in advance.
