1 - 14 of 14 Posts
the rear is lifted 9" on 33" toyo open country mud terrains. i need to lift the front and atleast tuck a 31" mud terrain. Anyone know what CHOPS did to lift his frontend?
· Banned
I really like seeing a project in the early stages.The pics leave a history for you and other members to look back on.A bit of advise,just work at your own pace as you can afford to fix whatever or mod whatever.No time cap on projects like these.No need to hurry to be able to post the progress here.Your with a number of folks who have done that and understand how long it could take.Very cool.That-a-boy!!. :clap: :clap: :clap: :banana:
Discussion Starter · #6 ·
Thanks Gary :)
Cool thing is that i make progress EVERYDAY. I get to work on my vehicle while i have down time at work...which lately has been alot :) :(
Discussion Starter · #7 ·
finally got some of the wiring harness cleaned up and the clutch fan on. I want to install 2 12" electric fans but i dont know if they will provide more cooling. anyone know?
· Banned
I have read that the 14" crown vic fan works better,but in either case,the fan shroud is the most important factor.
BTW-that is the route I am going to take once I deal with the cooling system on my swap.
The electric fans can deliver up to 2200 cfm of air movement. With the right rad that should be more than enough for a v8.
Great job on the mods so far, keep it up and soon you will have one killa stro...
Robert
Discussion Starter · #10 ·
im using the stock radiator. wanted to put a quadcore radiator in but it didnt fit :(
think ill be fine with 2 12" electrics running full time? i live in the valley of the desert...Arizona
Discussion Starter · #13 ·
I did some more work today. got my fiberglass dash in and almost got the body work done on it. got my matching center console in also. Got the window hole cut out on the dog house so i can go get my plexi tomorrow and heat/shape/heat/shape until it fits :) should be sexy
1 - 14 of 14 Posts
