Ok, A friend told me that perhaps the TPS is or has failed, causing the van to think that the pedal is floored.
By Quote:
"I had a similar issue awhile back with an old Buick. Complaint was long drawn out shifting and trans suddenly dropping out of overdrive and into 3rd at highway speeds and banging into gear. It turned out to be a TPS that was faulty and suddenly maxing out at 4.9v"
And he said every time the TPS spiked, the trans would downshift because the computer thought the driver was flooring the accelerator. It was also causing the trans to delay shifting.
My question is whats the best way to check to see if it is the TPS is faulty, maybe this will clear ALOT up.
By Quote:
