1 day ... 1 guy ... impressive .. keep up the thread ...
Man use Remflex gaskets before you throw in paper gaskets! PN 2004 Round port PN 2005 Square port. Under $30 on SummitMmusicman said:Wow... that's some amazing work you did on those headers Woodbutcher... they look GREAT!
It's amazing how they design headers to be shaped completely DIFFERENT than the heads they mount too.
I discovered a pretty nasty leak... despite having used high-temp Permatex on them. This was also the first time I ever used solid copper gaskets. The headers call for "round" port gaskets.
Due to budget reasons (plus the fact you can't really see them) .. I think I'm just going to live with nasty looking headers... but I like the idea of having them machined flat. Looks like I'm going back to rectangular port paper gaskets too. Not happy with the Hedmans (for several reasons) ... but they DO fit the van perfectly!
The accessory brackets are from the stock 92 V6 Astro.Mr_Roboto said:Silly question, are those L31 accessory brackets? If not what did they come from?
How I've done mine in the past is just have a ratchet strap that is run between the crossmembers of the subframe.icebrrg3rd said:What do you have holding the front of the tranny up? I need to do my engine pull soon and will probably go thru the front instead of the body lift this time.
-Andrew
Last time I did the pull I had made simple hooks out of wire coat hanger. I couldn't find them this time... so I used a pair of ratcheting tie-down straps. They are hooked from the eyelets in the trans, over the opening, and hooked to the seat bases in the van. Obviously, you do this first and get them tight before the pull. With wire hooks, you simply bend and twist them in place.icebrrg3rd said:What do you have holding the front of the tranny up? I need to do my engine pull soon and will probably go thru the front instead of the body lift this time.
-Andrew
What did you mean here?Mmusicman said:... Heads were last installed about 20 years ago... but mostly sat and didn't see a lot of use since then
Thanks, it was a lot of work.Mmusicman said:Wow... that's some amazing work you did on those headers Woodbutcher... they look GREAT!
