Hello! I am currently installing what is probably the second to last step in my vans lift and I wanted to share. I was offered some CST 3" lift spindles for the 1500. Price was good and it came with upper and lower arms. I am currently sitting at 3" body lift, 3" spring spacer, and a 1.5" ball joint spacer. Running 265,70,17 tires. Sawzall took care off the rubbing.
The lift spindles seem to be the exact same as far as lift goes compared to my factory spindles. The only difference being the 1500 spindle has (what I call) a top mounted ball joint. Where as my astro spindle is bottom mounted. Also the tie rod end is flipped but that's super easy. The top factory ball joint matched the taper of the CST, the tie rod matched, the brake caliper matched, the wheel bearing matched. Hell even the lower ball joint taper matched it was just upside down.
I am left with two options. I am either going to weld in a plate on the lower control arm to be able to mount a 1500 lower ball joint (which is a bolt in style) or press out my ball joint and flip it. Obvious concern with flipping the factory ball joint is that there is no circlip to hold the ball joint pressed in in that direction. Easy option being take the Dremel for a drive and add a ring or weld it in. Thinking it might be easier to just weld the plate in and bolt in the 1500 ball joint.
