Remove the rubber plug from the bottom of the backing plate (towards the inside of the truck) . Use a very small flat bladed screwdriver to push the self adjuster lever away from contacting the star adjuster. While the lever is not engaged with the star adjuster, you will be able to back down the adjuster which will allow the shoes to retract to a smaller diameter. You need to do this if the drums are "ridged" , which they probably are because if they weren't , then the drums would slide away from the shoes without any trouble. Ridged drums should be turned out on a lathe, if they will still be within spec. I prefer to install new wheel cylinders, shoes, hardware and drums. That way it's just like it came from the factory, and I don't have to worry about collateral damage down the road (and it just makes good financial sense.)
Sincerely, Bob
