I searched, and found topics very near to mine, but not quite........
Rear hatch on my '95 LT suddenly won't open, whether from button on dash or button on keyless unit. I'm hearing a little click-like solenoid sound, or whatever, and removed inside panel where jack is stowed, and there is a small box there which I think is the solenoid.....it is making noise when button is activate, but no release. Also, inserting key into rear lower door, the key cannot be turned.
Odd thing is, the hatch went from normal to inoperable in space of twenty minutes.
I "think" that I need to remove inner trim on the lower doors to access, but there are no screws visible, nor any clips that I can see. How does one begin the process of panel removal. Then, from other readings, it seems there may be a plastic piece which holds a metal rod in alignment to activate unlatching..........does this sound right? And that this plastic piece may not be doing its' job.
Any help much appreciated. Loading and unloading large black boxes with speakers and amps in them sucks without the use of rear door!
tomdad
tomdad
