1 - 12 of 12 Posts
When I installed my stereo in my 2003 cargo van I soldered into what I supposed was the rear speaker wires. These were the wires that were in the factory harness for the stock radio. Since I have a cargo van there are no rear speakers, but I assumed the corresponding wires were in the harness. They are supposed to be purple and light purple, and brown and light brown. I have no idea where the factory speakers are supposed to be so don't really know where to look. I have looked at the harness that goes thru the roof and saw there was another harness on the driver side that goes to the floor under some molding. I am hoping some of you experts can point me in the right direction.
I believe you tapped into the wrong wires.
2003 Chevrolet Astro Van Stereo Wiring Information
Radio Battery Constant 12v+ Wire: Orange
Radio Accessory Switched 12v+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Stereo Dimmer Wire: Brown
Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I found my speaker wires running in the harness into the back doors where the factory speakers would be mounted. I pulled them out of the doors (thru the loom) and hooked them to 2 speaker boxes that hold a 6x9 in each. Worked great.
Discussion Starter · #7 ·
Finally figured all of this out! I did originally solder the wires to the correct wires according to the above post^. The wires were not in the harness at all. I eventually found a connector under the mat, driver side, that contained the wires coming from the radio. So, now I have taped into the wires and have run speaker wires to the back. All is well again :)
Thank you for sharing - works for 2004 Astro as well.
Cheers!
03 Astro Cargo AWD G80
I realize this is an old thread, but wanted to provide a picture of the connector for the rear speakers and it's location near the emergency brake area. This is on my 03 Cargo.
The second pic shows where I spliced.
Hope this helps someone in the future. Cheers!
Unreal! stoked to have found this. I have a 2001 GMC Safari AWD Cargo and am looking to get some speakers in the back. Thanks for posting this.
HotBananas;
Also be aware there was an amplifier for the rear speakers ( not sure just what all models had this. It might have been part of the upgrade stereo package). That amp was located just to the rear of the fuel filler pipe ( driver side) behind the lower interior trim panel. (cargos may not have even had that trim)
Tire Wheel Vehicle Motor vehicle Automotive lighting
It is the grey rectangle
Rod J
1 - 12 of 12 Posts
