I need some help fast, I've unfastened my transmission completely, it is loose and sitting on the transmission jack. I've followed the removal procedure in the Alldata web site information but I can't seem to find the trick to get the transmission out. Basically it's trapped between the engine and the crossmember behind the transmission. The crossmember is also where the torsion bars for the front suspension are mounted, can I safely remove or at least unbolt and lower this crossmember? If so, how do you do this safely? Or is there a way to lift/lower/turn the transmission to get it out with the crossmember in place? The procedure in the Alldata web site does not mention removing the crossmember.
Thanks for any Help!
GMCarGuy
GMCarGuy
