Hello friends, I'm coming to you from Baja where about two weeks ago our AC stopped blowing cold. It wasn't much of a concern until recently as it's been getting hot driving across the desert and we will have a several day trek back to the US soon where it will also be hot!
I've been in full research mode as we live in this thing full time with 3 dogs (yes we're crazy) and their comfort is my main concern. First step was checking the compressor clutch which was not engaging. I've checked fuses, all are OK. I attempted to jump the low pressure plug as mentioned here on the forums and that was a no go. Finally, today, I jumped the AC Enable Relay and the clutch engaged and beautiful cold air blew into the cab! I checked the freon level with a very basic gauge and it's in the green.
I'm not much of a mechanic, I know enough to be dangerous and keep us hopefully rolling down the road. My question to you all is, would this be as simple as replacing the relay, or is there something else I should be looking at? I have access to an auto zone about 40 min away where I'm hoping they will have the relay. But I've also seen people on this forum report replacing this relay and it not fixing the problem. I'm camped out with friends for a few more days so I have time to poke around some more if yall have any ideas.
Also question #2 , is it safe to leave the relay jumped while driving so we can have cool air or is this not safe? The last thing I want to do is create a more expensive problem.
Sorry forgot to mention this is a 2005 cargo, no rear AC.
