After 3 years of using the prop stick I decided to replace it...
with a couple Strongarm gas springs also known as lift supports. $35 each at Schucks/Kragen/Checker/O'Rileys
First support the hatch with a prop stick. I'll rent you mine for 50 cents an hr. plus shipping. Rental time starts at time of shipping and ends at time returned.
Now pry loose the retaining clips (one at either end) there is no need to completely remove it, just pry it up enough to remove the support from the ball post.
Theres a notch to slip in a small straight blade screw driver.
Clip removed just so you can see what it looks like, no need to remove for install.
Ball socket with clip installed.
Now hold the dome light switch firmly (one per side) and unscrew the lift support and slide out. You might need to grab the lift ram with a pair of pliers to break it loose.
Now slide the new support into the dome light switch and screw on good and tight. Make sure you align the tab and slot of the ball catch and the dome light switch.
Now just push each end of each ball catch onto the ball post. They'll just snap in.
Make sure you ship my prop stick back ASAP as not to get charged any unnecessary rental fees :mrgreen:
