1 - 13 of 13 Posts
Hey folks, my local junkyard has one of those fiberglass high top roofs on an Astro and I'm tempted to pick it up and use it on my camper van build (2000 Astro cargo). I would like to have a roof rack though, which would not be possible the way most roof racks are attached... on top of the roof itself. My question is, has anyone added a roof rack over a high top, via some sort of side mount? That is the roof rack is attached to the van along the vertical reinforcements alone the sides of the van instead of the roof?
1997 AWD GMC Safari
Lots of people do it - for example, colorado camper vans is just one business that comes to mind that adds fiberglass tops with roof racks.
I did it too - fiberglass is pretty strong - unless you plan to put hundreds of pounds up there - which wouldn't be a good idea anyways since you shouldn't overweight the top end of a vehicle
Discussion Starter · #3 ·
Thanks. I should have googled first. I'll worry about that IF I can get the top. I just emailed Explorer, the company who makes the top, asking for advice on how to remove the top... they said when they remove them that the usually have to cut them off, they don't come off in one piece. But I have a feeling their first priority isn't keeping an old top intact when removing them. Might give it a shot.
When I had my hightop I checked with multiple companies as well as sites and I was told DO NOT DO IT!, the fiberglass top is rated at at best 10 lbs before it will crack. I say do not try it.
RWD's 2002 & 04
Edited. We missed that you meant the side of the actual VAN - haha. :D
Markmitch has a point about not to putting loads on fiberglass tops and there are a lot of old warnings about that.
Like many warnings, those came about because of people just doing whatever with no thought of the long run.
Hi-Top Manufactures and aftermarket pop-top builders fiberglass wood blocks inside the tops where strength is wanted.
With weight and forces distributed out onto an appropriate sized backer board or framing - anything is possible.
Mounted racks would not only be better supported and braced/backed on the sides, it also reduces chances of leaks.
*Biggest question you need to ask : How long will the donor van be there :?:
Most LKQ locations crush after one month, they strive for that now.
A Mom and Pop yard has it's own schedule and may work with you to get the top.
Explorer's priorities for sure aren't about saving any old tops- time is money - their money is in installing/selling the new top.
Now we as a group are tightwads (at least I am) and we're all about helping you get this top off - If you want to do it.
Some people will cut the whole van top off at junkyards because they'd rather remove all the BS at home.
*Will the yard charge more if you cut off the whole van top :?:
You'd be taking metal, that's worth money to them - fiberglass by itself has no scrap value.
*Will they charge more if you don't remove everything from the top :?:
LKQ can charge for anything left on the top, every light, speaker Etc.
Some of their employees will let you slide, hard to say until you get ready to pay.
The plus side of that is they only charge $50ish if you strip it down to (fiberglass van top) the official part name.
A Mom and Pop yard would probably never care about stupid things attached to the top.
You can remove it at the yard, do it in increments if there's no deadline.
Remove all the upholstered trim/woodwork from around the top's sides.
Flat head to pop off any screw covers, Phillips for screws and may be a few Square drive. Most of the square drive didn't have to be unscrewed.
You're also going to have to remove the front sun visors to take down the front headliner.
The visors have the weird screws that need a star shaped ''Torx'' bit, may can get away with just the right sized flathead.
Take down any overhead console, bring wire cutters.
The big headliner on the actual high top can have a BUNCH of a air venting, and wiring hidden under it.
I unscrewed all the face frames for lighting, speakers, also air vents but can't remember if I really had to remove the vents.
Wire cutters and a knife will come in handy, do know that I cut the main air vent line to pull the headliner out.
Once you get it gutted that's a good time to take a break or call it a day.
Now you're ready for the actual top removal.
Most screws were standard Philllip's and even had a raised head that fit perfectly inside the standard bit holder.
Some screws were easier to reach with the Phillips, some were better to take out by their head depending on angle of access.
By ANGLE I mean a few screws moved a little when they were tightened down long ago.
6 or 7 moved A LOT on mine and made it hard to get the proper angle to remove the screw without stripping the head of them.
Don't get mad at it or you will strip them, relax and skip them for last.
If needed, bend a little metal with a small pry bar or vice grips above or below these screws to get a better angle.
Needle nosed vice grips came in handy on some screws at different points.
Get all of those screws out and call your friends, the top is HEAVY.
Gavio gifted us a wire trick - bring some kind of strong wire, I used # 9 construction wire.
You'll probably see daylight coming through somewhere under the Hi-top's seal.
Poke wire through there and tie to a handle outside and a handle inside.
Work it around the perimeter to break the Butyl tape seal, you may also find you forgot to remove a screw.
The butyl gets pretty old and doesn't put up much of a fight at all.
Except there were some places on mine where it had squeezed out and overlapped edges when originally installed.
Those were thick, stubborn spots - used an old wood chisel to remove the bulk of those spots.
Yes it is pretty straight forward, easy and you won't damage the top.
Don't let Explorer make it sound hard, likely that they rarely remove a top.
If it's a good top and you like the style of it - get it.
It may be many years before you see another one.
Sportsboy painted his and I know many others have.
Sportsmobile owners were repainting with Lizard skin years ago - cheaper than bed liner back then.
Peace
Discussion Starter · #6 ·
I wasn't planning to mount anything to the top. I was saying, to mount a roof rack to the body, on the sides of the van, below the top, which would extend up above the top itself.
Discussion Starter · #7 ·
deafman said:
You can beef up supports in any way needed after you own the top.
Add wood blocks inside where you need strength / fiberglass the wood in.
*Biggest question you need answered: How long will the van be there?
A Mom and Pop yard has it's own schedule.
Yes saving the old top doesn't seem to be that company's priority - plus time is money - their money is in installing/selling the new top.
Now we as a group are tightwads and we are all about helping you get this top off - If you want to do it.
*Will the yard charge more if you cut off the whole van top?
*Will they charge more if you don't remove everything from the top?
The plus side of that is they only charge $50ish for (fiberglass van top) if you strip it down.
Flat head to pop off any screw covers, Phillips for screws and maybe a few Square drive. Most of the square drive didn't have to be unscrewed.
I think the front, top seatbelt holder had to be removed- or something in that area maybe just the plastic trim.
The visors or seatbelt thing needed a big star bit, hex or Allen wrench but mostly no special bits were needed.
I unscrewed all the face frames for lighting, speakers, also air vents but can't remember if I really had to or not.
6 or 7 moved A LOT, you can't get the proper angle to remove the screw without stripping the head of them.
Then bend a little metal with a small pry bar or vice grips above or below these screws and you'll be good.
You'll probably see daylight coming through somewhere under the high - top's seal.
Hey thanks, this is good info. I've been reading through the threads here and did come across the wire with handles idea, I think that's going to be key. I think it will be pretty straight forward once I get into it. I'm thinking of removing it all at the junkyard. That way, if I damage it and it doesn't come off in one piece, I'll just not buy it, haha. I currently have a roof rack on my van, I will have to remove it anyways, I was thinking of just slapping the new top on top of my van, strap it down, and driving it home. Junkyard is only about 3-4 miles away. It's brown though and my van is white, going to have to get that painted first. I'll post a separate thread if/when I decide to pull the top.
1997 AWD GMC Safari
I dunno mark, maybe if you put all the force on a dime, but no way my roof is cracking with only 10 pounds. I was up on top of it and it didn't crack, so it's good with at least 200.
I'd just mount it on top. Well, actually, I did. Our vans don't have drip rails like full size vans for example, so it isn't as easy to put a raised rack on - which I've seen people do on e-series vans plenty.
If you're planning on hauling huge loads of cement up there... then that changes things I'd say.
Also everything deafman said is high quality advice.
· Administrator
x2 fiberglass is pretty darn strong when done right. If you plan your rack properly, I'm sure you can get away with quite a bit.
A lot of good advice in here, I just had the junkyard cut the whole roof off the van at the pillars so I could work on seperating it at my shop on a bench top. Some of those hard to reach screws are much easier to access with the top upside down on a work table instead of looking up inside a van. My top didn't have butyl tape but a adhesive/sealant running the whole perimeter which was a real pain. A long blade that bends on an occilating tool made a word of difference over the other methods I tried.
I will be building a roof rack for it this week, the top I got has 4 wood stringers, glassed into the top for screwing the original interior ceiling into and should be more than strong enough to handle what I plan on loading onto the rack.
Also if you do remove it at the yard make sure to grab the metal/wood spacers the original conversion company used for spacing the interior corner framing and the van roof sheet metal.
PS when you think you have all the screws out, there's likely 2 more.
The wire and handle trick works very well for removing glued-in windshields.
Look for 'Piano' wire.
It is very thin, rigid, and very strong for it's diameter. It slices through the heavy rubber windshield gasketing pretty easily.
Rod J
Issaquah, WA
1 - 13 of 13 Posts
