HI IVE HAD THIS THREAD RUNNING ON THE UK SITE THE VAN RUNS FINE FOR A WHILE SOMETIMES UPTO 30 MILES THEN IT WILL NOT RESPOND TO THROTTLE THEN HUNTS AND SURGES FINALLY CUTTING OUT NO FIX SO FAR HERE IS WHATS BIN DONE TO DATE ......NEW EXHAUST SYSTEM INCLUDING CAT,
NEW FUEL PUMP ,and checked tank for debri
NEW DISTRIBUTER CAP
NEW ROTOR
NEW PLUGS
NEW LEADS
NEW PCV VALVE
ITEMS TESTED AND CHECKED
MAP SENSOR
ENGINE TEMP SENDER
CHECKED AND CLEANED IAC VALVE
CHECKED AND CLEANED EGR VALVE
CHECKED INTAKE AIR TEMP SENSOR
CHECKED AND TESTED THROTTLE POSITION SENSOR
.............. ANYMORE CLUES GUY'S SEEMS TO ONLY HAPPEN WHEN HOT IF YOU LEAVE IT FOR AN HOUR IT RUNS FINE FOR THE NEXT FEW MILES CAN BE AS LITTLE AS 12 OR AS MANY AS 35 ....THANKS IN ADVANCE Sandy and Mark
NEW DISTRIBUTER CAP
NEW ROTOR
NEW PLUGS
NEW LEADS
NEW PCV VALVE
MAP SENSOR
ENGINE TEMP SENDER
