1 - 6 of 6 Posts
i have a 97 gmc safari work van a few days ago i park my work van came back and it dint start untill a few min after the was a buzzin noice come from under the sterin wheel it a little box when i parked it back at my house it turned it off and on 2 make sure that it still work well the next day i go trie 2 turn it on i have no power in the van at all i mean no light i layed with ever thin like head light brack light the only thing that turned on was the radio but i huck it up 2 the battey and it was flashin and not workin.and now the van has buzzin from the same place befor i can turn it off by turnin on the light but nothin works i tied 2 scan it and i got notthin i have work on many vw and i have a feelin that it can be a open relay somin algone those line
i need ur help u guy got 2 help me if any one has a proble like i do u goota help me out i use this my work van i need 2 get back 2 work
Hi summitawd
Welcome to the Forum.
This sounds like a Main Power supply problem. I would check the connections on the battery first.
Make sure both Positive and Negative wires are "clean" and "secure".
How old is the battery?
Does the Alternator Gauge show charging when the engine is running?
Please let us know, were here to do our best to help. Thanks.:)
Discussion Starter · #3 ·
i un pluged the battery for few days then cleaned the wirein from the battery 2 the fuse box and the ground and the van turn one but after a hour the proble came back and it dead the battery is full charged
Hi summitawd
Discussion Starter · #5 ·
the battery is new hold a charged i cant get the motor 2 turn over when i say it dead nothing work at all no light come on but i cheack all my wirin and still good i did the big three swap AND 200 AMP attenader when i was doin my old audio i used 2 have 3000 rms no problems is was in it befro i turn it back in 2 my work van so thw wirin is right :ty: :ty: :ty: :ty: :ty: :ty: :ty: :ty: :ty: 4 look
Hi summitawd
Ok, then check in behind the battery where the fuseable links are hooked up and make sure none are blown. If you the fuseable links are fine and you still have a power short/draw, then start pulling fuses until you find the line the short/draw is on. You will need a multi-meter (volt meter) for this trouble shooting.
Please keep us updated, thanks.:)
1 - 6 of 6 Posts
