Since this only one that it adjustable, its worth checking out. the flat part of the flange of the pulley should be flush with the snout of the PS pump shaftWimpazz said:pulled the PS pulley on too far and it was out of alignment. Make sure your pulleys are all lined up straight.
We'd pay loose change to hear it or 4 bits to see it.Astrofarian said:... Will my belt get all Looney Tunes on me?-M!ke-
Careful, they are contoured and Factory 'smooth' for a reason.gman said:wire wheel ... abrasive ... clean my pulleys
There is a pulley available and a threaded hole on the engine to mount it in. The shorter belt is also available.Hello
I have a 94 Safari AWD.
I was wondering if I can reroute the Serp belt to remove the AC pump? Lines broke years ago.
Something is making noise. I know I would nee a shorter belt. How long?
Or is there a bypass pulley?
