You're more than welcome. Glad to help make my fellow van drivers lives a little easier.romeroom said:
Having owned seven Astros, I can tell you no. They are not easier to get to from the inside. I tried it once and have done it through the wheel wells ever since.romeroom said:Is it easier to get to the driver's side plugs from the inside?
As long as I don't have to replace glow plugs.Gary said:Orrrrrrrrrrr-you can take off the heads and leave in the plugs.That way once with the heads off you then take out the plugs.
Diesel anyone??.
sometimes the splashguard will pull past the snaps also, and can be buttoned back on. You just have to be careful not to rip the splashguard.99astroawd8seater said:When I do mine I always go through the side. The last time I did them I couldn't find enough 3/8" extensions to get there. I bought an extension set from Autozone (I know they suck, but it's the closest shop to my house) and the extension set doesn't fit squarely together. I know this sounds weird, but there's was a wobble where they came together. I don't know if they were designed like this, or if they are just crappy extensions. Well anyway when you fit a few of them together to get to the plugs they kind of "snaked" and moved around. Worked PERFECT for getting to the ones on the passenger side. The driver's side was much easier.
I can always get all six through the side. IDK why you would need to do it any other way.
The snaps for the inner splash guard usually just snap out with a screw driver and pop back in when finished, I'm sure that they make a tool for it though.
