1 - 8 of 8 Posts
· Premium Member
I just had to replace my power steering hoses. My leak was the high side. (Established with dye) I replaced both hoses at the same time. You can get to it, but it’s a little tough to reach. I cut my hoses to remove them. Are you sure it’s power steering leak? Could be from radiator.
Discussion Starter · #3 ·
Thanks for your reply. Yes it's power steering. I checked the reservoir and I can see it's lower than it was before the leak, plus it looks and smells like what is in the power steering reservoir.
There is a "power-steering cooler line" (it's just a long u-tube) located behind the bumper.
The hose that is connected to it may be leaking
It's also common for the "hydroboost" unit to drip (same power steering fluid)
It leaks (just sitting) and everything under it will be wet.
  • Like
Reactions: MechBob
I'm gonna guess it's leaking from the input shaft seal. PS leaks make a friggin mess. JMO, put I'd clean everything up the best you can using a grease remover, then remove the shaft linage boot.. Should be evident pretty quickly where the leaks coming from.
1 - 8 of 8 Posts
