I guess I never created a swap thread here, so I might as well do it today.
The van: 1987 CL with 123k miles. The van was very well kept before I bought it, and I intend to continue giving it a lot of love and care.
The engine: L31 SBC, which means all iron, Vortec heads, 1 piece RMS. It is likely getting a carburetor to replace the CPI. The engine had two rusted cylinders, so it is getting a rebuild. The heads will be ported. It will have roller rockers on original press-in studs, I-beam rods with floating wrist pins, a .030" overbore, a higher volume oil pump, and whatever else it needs along the way.
The trans: Although I expect to need a performance rebuild at some point, I am going to start with the stock original transmission just because I want to limit the time and money involved in making it a running and driving V8 vehicle.
The rear end: whatever is back there is how I'm starting off, but I want to put an LSD such as a TrueTrac in it. But that's going to wait until I convert to steel springs because I don't want to invest in the fiberglass spring rear axle.
Suspension: I have gone around and around and around about suspension. Although I like the idea of lowering the van, I think I need to keep it at stock ride height. As mentioned above, the rear end will eventually be converted to steel springs.
Wheels and tires: I have a set of Superior Dynomo wheels that I will install on the van once the wheels are ready and the tires are mounted.
