Didn't know where to put this. Not lifted, or lowered, but I want to upgrade to aftermarket things. It was either here or General.
Okay, searching around on here I found that the recommended things are a rear sway bar (can I use a front sway?) and a new set of shocks. I am aiming for a tighter and comfier ride, if that's possible.
Parts:
There were 2 recommendations for sway bars:
Belltech
http://www.summitracing.com/parts/BEL-5528/?image=large
Hellwig
http://www.summitracing.com/parts/HEL-7534/?image=large
Now, from what I read, the sway bar really helps with body roll, but nothing else. So I guess I need new shocks for a better feel? Should I look at springs? Some people tell me just lowering the van can increase handling, but I have a hard time believing that. All you're doing is moving the center of gravity a few inches down, or am I missing something?
Helpful quote I found:
http://www.summitracing.com/search/year ... s=Rank|Asc
(dunno if that link works for you. went to summit put in van info (2000 gmc safari) and looked for Munroe Shocks and Struts)
Is there anything else I should look at? I'm not completely sold on any of these things yet. Throw some opinions, please.
Install:
If you have any tips about it, I'd love to hear them. Do I have to drill holes in the frame for the sway bar?
Any ideas about the shocks? For front I've read to cut, or get a large amount of torque on, the top bolt and make sure to jack it up high enough to slide the old one out and the new one in. Is anything different because it's AWD? Haven't seen much on the rear shocks, I assume they are easier?
That's it for now. Thanks for reading.
P.s. - I love pictures
Parts:
Belltech
Hellwig
I looked up the Munroe shocks and got a little confused. I am a beginner. I know there are some differences in AWD, just don't know everything. I looked them up on summit and found an AWD specific front end set for the Sensa-Trac but not the Reflex. I don't know if I should look anywhere else for them. I don't know enough about them yet.Matrixx said:-As for Bilstiens, they are a very stiff shock and will give a very stiff and choppy ride. If you really want to improve handling, then I would recommend a rear sway bar (Belltech or Helwig) with a set of Munroe Sensa-Trac or Reflex shocks to tune-it up properly. This will give you good handling and ride.
Install:
