On my 2001 Safari the "service engine" light came on. Autozone told me that the error code pointed to, low coolant, coolant sensor, or thermostat. I added coolant , replaced sensor and disconnected the batt. cable. Light is still on. Ran the van for a while, outside temp. 65 degrees.
Gauge at around 150 degrees. Upper radiator hose was warm to the touch, but not hot to the touch. I have to remove the shroud, air filter box and hose. Is there anything else I need to be aware off while I am replacing the thermostat?
Thanks for any information
Frank
Frank
