I got everything off but the shock absorbers and control arms today.
I was able to find a family friend who let me work on it on a concrete area outside their garage. Its still raining off and on here. So my yard wouldnt work to do this, still too mushy and wouldnt want to be doing any jackstands on anything but concrete.
The driver side idler arm bolts were the toughest thing to get off so far.
That was until i got to the shock absorbers. I have a spare old ratchet and plenty of sockets so i think ill try bending the top bolts til they break because i put my vise grip on the lower end of the shock absorber rod and it keeps slipping. The only other thing i can think of is unbolt the lower end of the shock absorbers, and then when i lower the control arm with floor jack to remove the coil spring, it will give me enough access to hit the upper part of rod with grinder or sawsall. I think ill try snapping the top of first thing tomorrow then go from there...
Ive been soaking all the control arm bolts with pb blaster throughout the day as i was working on removing tie rods, sway bar, brake caliper, etc. Hoping by the time i get to those it has done its magic.
Driver side idler arm bolts were the toughest to remove, applied pb blaster every turn and used a 24" breaker bar. Didn't want to break them...
Old tie rods. I didnt get a pic of the rest of the steering hardware, i will tomorrow. But im replacing all the way from the wheel spindles to the pitman arm (with the exception of the sway bar itself)
My work cut out for tomorrow. Removing shock, spring, and upper/lower control arms. Will be rebuilding upper and lowers on both sides.
Driver side.
Checked the wheel bearings. Both sides seem perfect. I posted videos earlier in this thread and someone said they were sure the wheel bearings were shot on passenger side. I think the play it had in that side was due to bad idler arm...
Pitman arm seems to have no noticable play in it either.
Will update tomorrow, the sketchiest thing about all this is removing and reinstalling coil springs but i feel pretty good about it using a heavy duty floor jack.
