1 - 9 of 9 Posts
Hello, new owner here of a 1997 AWD EXT Astro van with 120K miles. I was getting a slow and steady oil leak coming from the timing cover. Brought to mechanic to replace cover and seal, job cost around $1,400. Leak persisted after job was complete and they took it back in and said they replaced defective cover with another new cover. Leak re-appeared after a few months of light use. I got underneath the engine to verify where the leak was coming from and found this. It looks like when I brought it back the second time they just slathered the seal with some type of caulk. At this point I feel like I was ripped off and lied to. I Also found a black cable management hose with wires that have no connector just floating loosely un-terminated in the same area (visible in the photos). Bringing it back in next week and looking for some input in case this is normal or if anyone has any experience or advice with this issue. Any help much appreciated.
-Rex
Automotive tire Hood Motor vehicle Automotive lighting Bumper
Automotive parking light Hood Automotive lighting Automotive tire Grille
Automotive tire Asphalt Plant Automotive design Rim
Yes... and it is par for the course.
Money back - then look for a better, honest mech.
"Stealerships" generally charge the most, but generally fix your car right. Mostly...
The 4.3 V6 in these Vans is not exotic or "Old"... just ask Mercury Marine and Kohler Corp.
I see them in farming, BU generators - cell towers and High-End Chippers - Asplundh.
Discussion Starter · #3 ·
Thanks for the response, I figured as much. They seemed like a trustworthy local family shop here in Long Beach, CA. As time will always prove, talk is cheap. Will give an update after returning this week for a refund.
Discussion Starter · #7 ·
Wow, for $1400 you should have gotten a really first rate job. The timing cover is the same as any small block Chevy engine. It's not like they're having to pull the cover off a late model OHC engine, but they're charging about the same labor. An then not stand behind their work but tell you a story and try a cheap patch job!!
Give them a chance to do the right thing, but this where having a friend who is a lawyer would come in handy. One phone call or letter and 99% chance it'll be fixed right or you'll receive a $1400 check. (They're counting on you not hiring a lawyer bc that would probably cost more than $1400.)
Try Consumer Affairs as mentioned above. Or small claims court (look up the process for your state). Or if nothing else, tell your story on social media (be sure to stick to the facts).
Good luck!
It is almost impossible to get them not to leak there, new oil pan and front cover with the proper silicone placement per FSM is the key, they did leave the factory with silicone visible between the pan and the front cover FYI. We won't even do that job without replacing both and won't guarantee it won't leak at some point.
1 - 9 of 9 Posts
