Hi all. I’m currently running stock alloy rims with 215/70R15 on my 2003 awd and I never liked the look of it.
I’ve been looking for a basic steel 5 leaf rims similar to my 01 cargo Astro (5 lug) and I found this on the web - stock Chevy 255/70R16 with all terrain tires.
So I’m looking for some advice from you who have played with tire upgrades before and my questions are the following:
1. It looks like the only difference to my current tire is adding about 2” to the width, overall diameter should be the same, it it correct?
2. Am I looking for any clearance issues especially on front when turning?
3. I assume there should be no to minimal impact on the transmission since the diameter/radius stays the same, is it correct?
4. Doe’s upsizing the width affects my “immediate stopping length”? I think it will be increased since the same weight sits on larger surface.
5. How bad the MGP might drop?
6. And the last, slightly off topic, why do all Astro spare tires come oversized, 18” I believe?
Your help is much appreciated!
