Q. I want to lower the van while being better off for towing, is it feasible to have the best of both worlds or is it more of a one or the other? I was thinking about just planning on flipping the axle with the new one in since the perches would have to welded on I can just get them put on upside down.
What do you guys think?
Reason is that I recently pulled something I probably shouldn't have, 35 miles home;
I am now getting some rear end wheel bearing noise and thought it wouldn't hurt to upgrade (I know changing rear wheel bearings isn't too hard of a job). There is a local performance shop that makes custom rear ends, I have done some reading on what I should replace with. However, I would like some advice on which axle to get or if I should go another route. I was looking at a Ford 9", Dana 60, and GM 12 bolt. These are all in close proximity to each other price wise from Moser, but I haven't looked into aftermarket support for each specific axle.
http://www.moserengineering.com/Housing-Axles.dept
:text-thankyouyellow:
