1 - 11 of 11 Posts
· Premium Member
Ok, this is weird - Yesterday I was driving to a Pull a Part Yard, and I noticed that when I use the Left turn signal, its a solid light both inside the dash and the lights outside, however, the right turn signal works flawlessly, I checked fuses, all is good, people think a brake light is out but its a turn light. LOL
· Super Moderator
05 Astro AWD
Generally, replace the bulb. One of the elements is broken, causing the solid light.
· Premium Member
Discussion Starter · #6 ·
Yep, it was the bulb in the tailight - I replaced it, and it works now, but its erratic, not slow like the right turn signal. :confused:
· Super Moderator
05 Astro AWD
Did you check/clean the socket while you had the bulb out? If the socket is clean and clear of corrosion, I'd start tracing the wiring.
· Premium Member
Discussion Starter · #9 ·
Got the issue fixed, I actually bought a single filament bulb, and needed a 2 filament, so back to the AZ to get the correct bulb, they all look the same.
· Super Moderator
05 Astro AWD
Glad you got it fixed ;)
1 - 11 of 11 Posts
