Todays update:
I decided to do the rust treatment first since the van was already apart. I don't have a hose I can use at home so I'm going to hit the diy car wash in the morning.
Treating an area this big all at once was a hell of a job but I'm glad I discovered it before it was too late. Here are my steps in case anyone's doing this in the future.
Treating floor rust if you're a total amateur:
Equipment:
- Grinder
- Vacuum - Super useful for this job.
- Ear protection, eye protection, n95 mask.
- Rust Check Primer
- Tremclad Rust enamel.
- Dupli Colour Wax and Grease remover.
Steps:
1. Wire wheeled forever. Tried to get as much of the rust off the metal as possible and made sure all the loose paint and rust were gone.
2. Cleaned. Vacuumed and wiped everything down with water and a cloth. Then Cleaned with a grease and wax remover. The grease and wax remover I used was not good and left sort of an oily film even after waiting a while. It also smelled like death and probably took 2 years off my life. I ended up using a spray bottle of super diluted soapy water and going over everything again.
3. Primer. Because I was finishing in white, I used a grey primer so I could later tell that I'd hit everything.
4. Paint. I waited about an hour for the primer set and then applied one coat of the enamel. Waited about 45-60 minutes before applying the second coat.
- Wire wheeled and applied rust paint to the seat bases, seatbelt mounting points.
I don't know if I mentioned, but I ended up just doing the whole floor. I used 2 cans each of primer and enamel. It was a stretch and if doing again, I would have 3 cans of each. I may go back and do another coat of the enamel in the rear of the van.
Thanks everyone for all your ideas and support. Following suggestions, I'm only going to put the drivers seat back in and turn a hose on it tomorrow. Cheers.
