Hooray!!! The V8 is finally in!!! It dropped in easily (this past weekend). It went in like it was made for it! It was a one man job too!
I installed it complete with headers attached, new plugs, water pump, harmonic balancer, pulley, and oil filter all in place. The headers measured almost exactly the same distance as the stock exhaust coming out, and went in easily with NO clearance issues whatsoever! Also, NO need at all to pull the bumper... just angle back the motor and keep stepping it down and in! You only need to have the van angled up high on jack stands to match. Simple!
The only initial minor trouble I had is that I didn't have the motor positioned and angled correctly on the lift, as seen in this first photo.
It was angled too far down in front... and the hook was not tight enough. Although I was able to lift the front by hand, I still didn't have the hook tight enough for overhead clearance when I got it to the motor mounts.
Here are some photos of it tighter on the hook, and angled better...
The front opening of the lift plate was ideal, giving it a much better angle to go in! This is the first time I ever used a lift plate, so you see the chain as a fallback. The biggest advantage of the plate is that it kept the block strait going in.
A few final things left... basically slide in the motor mount bolts and attach transmission. But first I had to wait for the rain to stop before crawling underneath! lol
Adjustable JTR V8 mounts are awesome! Quality stamped steel product... seriously worth every dollar! Tighten trans up to block first.. then final tightening of mounts. Went in perfectly!!! One very important note: you will need 1/2 longer 5" Grade 8 bolts for the thicker mounts! Thank you icebrrg3rd for that tip!
Plenty of room... everything completely cleared with room to spare!
DONE!
The ONLY unrelated issue I had was overlooking the fact that the 1970 flexplate did not match the later model 700R4 lockup torque converter bolt pattern, which I didn't notice until after I bolted the trans to the block. Fortunately, I had another later model 350 flexplate laying around that had "dual pattern" holes, which worked perfectly. A minor inconvenience caught early... fortunately.
Overall, not too pretty... and the alternator, pulleys, and A/C accessories will cover most of it. But it's a runner.. and is going to be awesome!!!
DONE!
